Facet fuel pump wiring
Post by Jordi » Tue May 28, 2013 9:56 am
How have we all wired our in?
Obviously it needs an earth and a switched life, preferably from the ignition. Just wondered who had wired it where.
Ladaman
Re: Facet fuel pump wiring
Post by Ladaman » Tue May 28, 2013 10:13 am
You've got the wiring sorted with what you say.
For location of the pump. Pumps push better than suck, so ideally near to the tank.
Having said that I put one on the bulkhead in my sons Vitara and it was never a problem.
So wherever suits seems to work.
kibris
Post by kibris » Tue May 28, 2013 12:24 pm
Jordi wrote:How have we all wired our in?
I rewired all my Sammy and wired the facet pump from an ignition live from the fusebox - oh and i moved mine from mthe back to under the bonnet - works fine and is accesable if/when it goes wrong!! read "be prepared" thread :(
Post by twiss » Wed May 29, 2013 2:43 pm
I bolted my fuel pump to the inside of the wing, then used the attaching bolt for an earth.
Then I wired in a relay to activate the pump, taking the relay activation signal from the positive terminal on the ignition coil... now the pump starts with the key :)
