alternator problems
- suzukisteve
- Suzuki Guru
alternator problems
Alright guys? Well after having a tinker at the weekend I found my alternator is not putting enough power.
My problem is this, I took some numbers off it and it doesn't match the one listed for the zuke.
I've attached a photo of the numbers from my current alternator. Blue print say it's a 35amp unit.
Any ideas?
Steve
Any ideas?
Steve
- 20121112_073325.jpg (2.02 MiB) Viewed 7841 times
pickle power!
- suzukisteve
- Suzuki Guru
Re: alternator problems
Thinking about it, is there a heavy duty option? As I run a fair amount of lights etc
pickle power!
- suzukisteve
- Suzuki Guru
would an alternator off a g16a vit engine work?
if not im pretty sure there is a 100amp volvo one layin about somewhere
pickle power!
you can make any alternator fit as long as they have a pulley that matched the belt type you have.
- suzukisteve
- Suzuki Guru
From what I could find its a landrover defender one
Can I assume it no longer has the original connector plug.
Bosch 9120144289.
Bosch 9120144289.
- AEA6153 (b).jpg (69.48 KiB) Viewed 7799 times
- aea 6153 (a).jpg (70.86 KiB) Viewed 7799 times
- suzukisteve
- Suzuki Guru
ah brilliant! cheers dude, the vit one was a no go due to the fact its a multi rib belt as opposed to a v belt. however im gonna dig out that ol volvo one and have a look. i know its a v belt pulley so its just a question of bein able to wire it up ok. 100amp as well, so extra heavy duty if it'll go on
steve
steve
pickle power!
Bit of info if you do go for a high output unit
http://alternatorparts.com/do_i_need_a_ ... y_wire.htm
- suzukisteve
- Suzuki Guru
Cheers darrell. Dude with that in mind, I've just received a 40 amp unit. Would this be enough to power the zuke?
I'm running 4 spots, each of which is using standard 55w bulbs. Only other bits I have are a cd player and a small
Reversing light. But obviously is only used in short bursts.
Cheers dude
Steve
Cheers dude
Steve
pickle power!
Useful formula
Watts divided by volts = Amps
IE: 4 spotlights at 55watts each = 220watts
220 divided by 12 (volts) = 18.33 amps
It should be ok but depends on the other loads and how long you use them for. I assume you would still have the standard headlights on. If you tootling around a field shooting the alternator rpm may not be high enough for a good charge rate though.
