alternator problems
suzukisteve
alternator problems
Post by suzukisteve » Mon Nov 12, 2012 8:53 am
Alright guys? Well after having a tinker at the weekend I found my alternator is not putting enough power.
My problem is this, I took some numbers off it and it doesn't match the one listed for the zuke.
I've attached a photo of the numbers from my current alternator. Blue print say it's a 35amp unit.
Any ideas?
Steve
pickle power!
suzukisteve
Re: alternator problems
Post by suzukisteve » Mon Nov 12, 2012 9:23 am
Thinking about it, is there a heavy duty option? As I run a fair amount of lights etc
pickle power!
suzukisteve
Post by suzukisteve » Mon Nov 12, 2012 1:08 pm
would an alternator off a g16a vit engine work? :brows:
if not im pretty sure there is a 100amp volvo one layin about somewhere :guns:
pickle power!
Post by ScottieJ » Mon Nov 12, 2012 2:56 pm
you can make any alternator fit as long as they have a pulley that matched the belt type you have.
suzukisteve
Post by suzukisteve » Mon Nov 12, 2012 4:16 pm
awesome ill order up a vit one an see if it fits :smokin:
pickle power!
Post by Darrell » Mon Nov 12, 2012 7:24 pm
From what I could find its a landrover defender one :yuk:
Can I assume it no longer has the original connector plug.
Bosch 9120144289.
AEA6153 (b).jpg (69.48 KiB) Viewed 7800 times
aea 6153 (a).jpg (70.86 KiB) Viewed 7800 times
suzukisteve
Post by suzukisteve » Mon Nov 12, 2012 7:47 pm
ah brilliant! cheers dude, the vit one was a no go due to the fact its a multi rib belt as opposed to a v belt. however im gonna dig out that ol volvo one and have a look. i know its a v belt pulley so its just a question of bein able to wire it up ok. 100amp as well, so extra heavy duty if it'll go on :guns:
steve
pickle power!
Post by Darrell » Mon Nov 12, 2012 9:05 pm
Bit of info if you do go for a high output unit
http://alternatorparts.com/do_i_need_a_ ... y_wire.htm
suzukisteve
Post by suzukisteve » Tue Nov 13, 2012 12:22 pm
Cheers darrell. Dude with that in mind, I've just received a 40 amp unit. Would this be enough to power the zuke?
I'm running 4 spots, each of which is using standard 55w bulbs. Only other bits I have are a cd player and a small
Reversing light. But obviously is only used in short bursts.
Cheers dude
Steve
pickle power!
Post by Darrell » Tue Nov 13, 2012 7:46 pm
Useful formula
Watts divided by volts = Amps
IE: 4 spotlights at 55watts each = 220watts
220 divided by 12 (volts) = 18.33 amps
It should be ok but depends on the other loads and how long you use them for. I assume you would still have the standard headlights on. If you tootling around a field shooting the alternator rpm may not be high enough for a good charge rate though.
