Distributor problem
palmer
Distributor problem
Post by palmer » Sat Nov 03, 2012 5:17 pm
Hi guys i nearly have my 1.3 lump up and running now but i am not getting any sort of spark from my ht leads?.
I have put the new ignition coil in as well but cause she was a 410 she has a ballast resistor which i have kept on.
Can i still use the resistor with a 1.3 coil or do i need to bypass that, also it gets very hot.
I would be very grateful for any help thanks.
1.3 engine
Webber carb
Roll cage
Spoa
32 mm wheelspacers
Extended brake lines
31" Bronco Grizzerly Claws
MONSTER ENERGY DISCO KILLER!!
Re: Distributor problem
Post by ScottieJ » Sat Nov 03, 2012 5:25 pm
So have you got the 1.3 coil? If so don't run the ballast resistor.
The 1.0 and 1.3 coils have different resistances so must be used with the correct dizzy.
I presume the 1.3 you fitted has the electronic dizzy so no points?
palmer
Post by palmer » Sat Nov 03, 2012 7:38 pm
Im going to sound stupid but how do i tell the difference between electronic and not?
Yes i have fitted the 1.3 coil that came with the engine.
Sorry i feel as if i should know that. :oops:
1.3 engine
Webber carb
Roll cage
Spoa
32 mm wheelspacers
Post by Darrell » Sat Nov 03, 2012 9:36 pm
It should be connected like so --
413 Ignition circuit.jpg (20.18 KiB) Viewed 6610 times
If you unclip the distributor cap it should look like this--
palmer
Post by palmer » Sat Nov 03, 2012 9:43 pm
Cheers darrell thats a big help, yes my dizzy looks like that :salute:
Going to get on it in the morning cheers guys.
1.3 engine
Webber carb
Roll cage
Spoa
32 mm wheelspacers
Post by ScottieJ » Sat Nov 03, 2012 10:14 pm
As darrell says ;) ^^^^
Buuuuttt as yours was a 410 there could be a brown wire in the loom that used to be part of the ballast resistor wiring and not for the rev counter (if you have one?) so just leave that disconnected at both ends.
palmer
Post by palmer » Sun Nov 04, 2012 7:24 am
Cheers scottie :doublethumbs:
1.3 engine
Webber carb
Roll cage
Spoa
32 mm wheelspacers
