wiring diagram for the ignition barrell?
so im fitting an immobiliser and need a diagram for the ignition switch/barrel so i can have the immobiliser switch the start wire via a relay...
or would it be easier to switch the solenoid?
and i cant switch the fuel pump considering its mechanical lol...
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Re: wiring diagram for the ignition barrell?
How many circuits is it immobilizing, normally it's 2. The coil supply and the wire to starter solenoid.
well it only comes with one relay so i think ill be doing just the coil supply..
and if anyone knows the wiring for the hazard switch then i can do the hazard light feature for when i use the remote central locking..
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
I would just break into the positive supply to the coil (black/white wire)
Here's a diagram anyway
- Supply.jpg (65.73 KiB) Viewed 20505 times
do you know the colour of the hazard light switch wire i need to use?
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
I'm afraid to say that no single wire will make the hazard lights work. Well not that I can see.
- indicator circuit.jpg (51.42 KiB) Viewed 20494 times
the instructions are not the best but here they are..
http://www.sniperautomotive.com/support ... Manual.pdf
cant i just wire into the hazard switch?
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Am I right in thinking you have all this
But you only want to use the immobilizer ??
