wiring diagram for the ignition barrell?
Jay18
Post by Jay18 » Thu Sep 20, 2012 6:57 pm
so im fitting an immobiliser and need a diagram for the ignition switch/barrel so i can have the immobiliser switch the start wire via a relay...
or would it be easier to switch the solenoid?
and i cant switch the fuel pump considering its mechanical lol...
2003 Grand Vitara 2.0 16v
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Kenwood Double Din Head Unit
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
SuzukiPicsUK on Instagram
Re: wiring diagram for the ignition barrell?
Post by Darrell » Thu Sep 20, 2012 7:11 pm
How many circuits is it immobilizing, normally it's 2. The coil supply and the wire to starter solenoid.
Jay18
Post by Jay18 » Thu Sep 20, 2012 7:21 pm
well it only comes with one relay so i think ill be doing just the coil supply..
and if anyone knows the wiring for the hazard switch then i can do the hazard light feature for when i use the remote central locking..
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
Post by Darrell » Thu Sep 20, 2012 7:23 pm
I would just break into the positive supply to the coil (black/white wire)
Post by Darrell » Thu Sep 20, 2012 7:24 pm
Here's a diagram anyway :thumbup:
Jay18
Post by Jay18 » Thu Sep 20, 2012 8:03 pm
do you know the colour of the hazard light switch wire i need to use?
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
Post by Darrell » Thu Sep 20, 2012 8:23 pm
I'm afraid to say that no single wire will make the hazard lights work. Well not that I can see.
indicator circuit.jpg (51.42 KiB) Viewed 20498 times
Post by Darrell » Thu Sep 20, 2012 8:26 pm
:help: Could you post up the wiring instructions. :thumbup:
Jay18
Post by Jay18 » Fri Sep 21, 2012 11:28 am
the instructions are not the best but here they are..
http://www.sniperautomotive.com/support ... Manual.pdf
cant i just wire into the hazard switch?
16x7 Black 8 spokes
Nexen road tyres
32mm spacers
Hidden CB radio
Cruise Control
GV Build Thread
SJ Build Thread
Facebook
Post by Darrell » Fri Sep 21, 2012 1:05 pm
Am I right in thinking you have all this
sniper x2.jpg (73.99 KiB) Viewed 20476 times
But you only want to use the immobilizer ??
