revs racing
revs racing
Hi guys just swapped engines on my sj knackered g13B to an ok g13A everything runs as it should,
except when i switch headlights on revs race upto 3000 rpm. any ideas? cheers mike
Re: revs racing
Welcome to the club
Needs adjusting.....................or just unplug the bugger.
- Idle up SJ 413.jpg (256.4 KiB) Viewed 8252 times
- 100_4865.jpg (229.47 KiB) Viewed 8252 times
Re: revs racing
cheers guys "removed the bugger" spot on everthing works. MOT tommrow fingers crissed sorry
dyslexia stops me posting as much as i like, ages rihgting post again thankyou
Re: revs racing
MOT failed offside front axle swivel joint has excessive play, can this be adjusted or will it need replacing?
- Ladaman
- Suzuki Guru
Re: revs racing
I'd think it's either knackered kingpin bearings or it needs some shims removing.
Probably the bearings need changing though.
- donkeychomp
Re: revs racing
any idea where i can buy a new bearing?
Re: revs racing
Hi OldSkool .... If you want me to get you them from my local parts man send me a PM and ill try and sort you out
Maruti Gypsy MG410
Electric Fan upgrade
5 speed box
30" Insa Turbo Saharas
1.5" Shackle Lift
LWB Pickup Conversion
Daymaker led lights
5 speed box
1.5" Shackle Lift
Daymaker led lights
Re: revs racing
Kingpin bearings can be bought on eBay or most bearing suppliers, if you search on here in the axles sub forum Scott has a sticky on axles, and it lists all the bearings/dimensions etc. Just remember there's two fitted one top & one bottom on EACH side so four kingpin bearings for the front axle.
Just had a look in garage, they are 30302 J2, if you google it you will find them all over.
