If you are after some door pockets the you can use a pair from the front of a Mk1 shogun they fit nice and give some where to put things like maps etc
to fit them all you have to do is remove the SJ door card flip it over than work out where you want the pockets so they don't interfere with the handle and window winder
then put some oil or wd40 round the lip on the mitsu door pocket and place on the back of the door card this will give an out line of where the screw hole will go so you can drill the holes in the rite place
remove and drill the holes and place the door pockets on the other side and screw on
re affix the door card and enjoy the new space
This article was written by Pete Hall and was originaly posted on Difflock and can be found HERE
