Ignition barrel
Ignition barrel
Post by ROBBIE » Tue Aug 20, 2013 10:29 am
I need to get rid of the above as its falling to pieces. I already have a start button and now want to put a switch in. So the question is what will I need, a switch obviously, wire, relay? Anything else?
Re: Ignition barrel
Post by turbo-tom » Tue Aug 20, 2013 11:10 am
be carefully mate if you get rid of the ignition barrel as then you take out the steering lock and mr mot man dont like it!
Re: Ignition barrel
Post by ROBBIE » Tue Aug 20, 2013 11:21 am
Hasn't had a steering lock since I got it :lol: I have been told that they are going to bring the steering lock into the mot, if there isn't one it can't be tested it can't fai
Re: Ignition barrel
Post by turbo-tom » Tue Aug 20, 2013 11:32 am
:hahaha: you should be fine then!
suzukisteve
Re: Ignition barrel
Post by suzukisteve » Tue Aug 20, 2013 11:38 am
you should be able to use one of those isolator switches with the red key. that way its not as easy to steal. id imagine a realy and in line fuse would be advisable as well bud :thumbup:
although dont ask how because I tend to struggle with electrickery a bit. its the not being able to see it that does me in :S
pickle power!
Re: Ignition barrel
Post by ROBBIE » Tue Aug 20, 2013 1:22 pm
:lol: i have the same problem with lectrik total confusion. Already got a battery isolater switch, now want something hidden away
suzukisteve
Re: Ignition barrel
Post by suzukisteve » Tue Aug 20, 2013 1:40 pm
hmmm. could put a kill switch hidden underneath the dash somewhere. so you have to switch the kill switch then the isolator then the button. seems long winded but it won't get nicked
pickle power!
suzukisteve
Re: Ignition barrel
Post by suzukisteve » Tue Aug 20, 2013 1:42 pm
failing that hide a big ol rottweiler in the back :hahaha:
pickle power!
Re: Ignition barrel
Post by ScottieJ » Tue Aug 20, 2013 1:48 pm
why not just get a new ignition barrel, in fact I might have one ;)
Re: Ignition barrel
Post by ROBBIE » Tue Aug 20, 2013 4:29 pm
ScottieJ wrote:why not just get a new ignition barrel, in fact I might have one ;)
Every where I looked they wanted a minimum of £25 and trying to do it as cheep as pos :oops:
