Ignition barrel
Ignition barrel
I need to get rid of the above as its falling to pieces. I already have a start button and now want to put a switch in. So the question is what will I need, a switch obviously, wire, relay? Anything else?
- turbo-tom
Re: Ignition barrel
be carefully mate if you get rid of the ignition barrel as then you take out the steering lock and mr mot man dont like it!
Tom
Ford Fiesta ST
Ford Fiesta ST
Re: Ignition barrel
Hasn't had a steering lock since I got it I have been told that they are going to bring the steering lock into the mot, if there isn't one it can't be tested it can't fai
- suzukisteve
- Suzuki Guru
Re: Ignition barrel
you should be able to use one of those isolator switches with the red key. that way its not as easy to steal. id imagine a realy and in line fuse would be advisable as well bud
although dont ask how because I tend to struggle with electrickery a bit. its the not being able to see it that does me in
pickle power!
Re: Ignition barrel
i have the same problem with lectrik total confusion. Already got a battery isolater switch, now want something hidden away
- suzukisteve
- Suzuki Guru
Re: Ignition barrel
hmmm. could put a kill switch hidden underneath the dash somewhere. so you have to switch the kill switch then the isolator then the button. seems long winded but it won't get nicked
pickle power!
- suzukisteve
- Suzuki Guru
Re: Ignition barrel
why not just get a new ignition barrel, in fact I might have one
Re: Ignition barrel
Every where I looked they wanted a minimum of £25 and trying to do it as cheep as posScottieJ wrote:why not just get a new ignition barrel, in fact I might have one
