Me second Zuke
Crisdolf
Me second Zuke
Post by Crisdolf » Mon Mar 04, 2013 7:57 pm
Just brought me 2nd Zuke a 413 this time towed it home as no battery ,and ideas what I should do before trying to start it ?
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Crisdolf
Re: Me second Zuke
It's been stood a couple of years
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Me second Zuke
Post by turbo-tom » Mon Mar 04, 2013 7:59 pm
give the engine, drivetrain and brakes a good look over, clean out the brakes etc bleed them, service the engine, replace all the oils and fluids give it a clean and then go from that , thats what i would doo ;)
Crisdolf
Re: Me second Zuke
Post by Crisdolf » Mon Mar 04, 2013 8:09 pm
Will the carb need draining ? I heard the cards on theses are a pain ?
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Me second Zuke
Post by turbo-tom » Mon Mar 04, 2013 8:13 pm
what carb is on it mate?
Re: Me second Zuke
Post by ScottieJ » Mon Mar 04, 2013 8:22 pm
If its been sat a long time I always pull the plugs and pour a bit of oil into each cylinder, enough to coat the top of the piston, then loosely fit the plugs (1-2threads) to stop any crap getting in and leave it to sit for a few days so the oil can settle. Pull the plugs back out and turn it over by hand a good few times and shine a torch in each cylinder to make sure all the oil has cleared, refit plugs and give it a few turns over by hand. Add some fresh fuel, check oil/water etc and fire her up.
Crisdolf
Re: Me second Zuke
Post by Crisdolf » Mon Mar 04, 2013 8:48 pm
No idea what carb ,it's a auto choke that's all I know ,bit of engine oil for pistons ? Or something like 3in 1 oil ?
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
OllieSJ
Re: Me second Zuke
Post by OllieSJ » Mon Mar 04, 2013 8:52 pm
nice m8 were did u find it i havent seen it !
Re: Me second Zuke
Post by Jordi » Mon Mar 04, 2013 8:54 pm
Boggo standard oil, or duckoil. Something quite thin generally penetrates better.
Crisdolf
Re: Me second Zuke
Post by Crisdolf » Mon Mar 04, 2013 9:52 pm
Bloke had it in his back yard for 4 yrs ,rust round arches and bit round screen but that's about it ,4 conways on it like new and if u see spare on back there's 4 of them too plus as a winch on the front,my plans are take the folding bench seat out the back replace soft top ( no leaks or splits) for hard top and go from there :)
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
