What Wire?
- choochoo
What Wire?
I want to replace the + wire on my sj from battery to starter and alternator or may link from starter over to alternator but needs to be a thick wire. Any idea what thickness or amp etc. ive searched ebay and its all 1.5mm which is to thin
Thanks Tom
Thanks Tom
I'D RATHER PUSH MY SUZUKI THEN DRIVE A LANDROVER
Re: What Wire?
I Googled UK Vehicle Battery Cable Specifications and there are quite a few choices you can click on - this web site looked particularly helpful and easy to understand but it does seem that you have to know the spec of what you need. Can you not do some measuring of your existing cable or maybe someone else's identical vehicle to arrive at a decision? I can measure the cables on my 410 if that helps.
http://www.vehicle-wiring-products.eu/V ... ycable.php
Re: What Wire?
bit of 25mm2 flex or tri-rated will do the trick for an alternator cable upgrade. guess the cable for the starter is about that size so if you wanted to upgrade that maybe use a bit of 35mm2.
Dan
Dan
Re: What Wire?
I used a bit of cable that was left over from a winch install
Re: What Wire?
The specs for the starter on the SJ 1300 and the vit 1600 are
So I assume a cable rated at 150amps would suit ??
To be honest I would take the old cable to the motorist shop and let them match it, I know my local store sells it off the roll, or as above http://www.vehicle-wiring-products.eu/V ... ycable.php
I don't fully understand the figures IE Locked rotor current
Trying to start a locked/seized engine maybe
Re: What Wire?
The standard cable from the battery to alternator has a fuselink on it to protect the main loom.
Also the wiring shows all the loads are spliced off it and therefore the supply to them can come directly from either the alternator or the battery. I guess you could disconnect the original wire and isolate at the alternator end, but leaving the fuselink end connected to supply everthing and run a new wire from the alternator direct to the battery. What's wrong with the original wire?
- Alternator wire.jpg (22.56 KiB) Viewed 8425 times
Re: What Wire?
The only wire I'd change is the battery to starter motor.
The only reason I actually changed mine was because I moved the battery to the passenger side.
- choochoo
Re: What Wire?
Fair play you guys are so helpful . I pay membership on a forum and if I asked this type of question it would get no replys . infavt any question tbh .so big thanks.
I need to basicly rewire it because when I removed the body I think I lost some wire or I've forgot where it plugged in . Ill take some pictures in abit see what u think
Thanks again
Thanks again
- choochoo
Re: What Wire?
In the picture ur see short black wire with plug, thats from the alternator , then theres two other wires close to it, both white with yellow stripe, not in picture shown i have another power wire from starter to battery,hope u understand that
Re: What Wire?
The white and yellow wire goes to the alternator main output terminal. There is a connection in that large plastic sleeve that would go to this terminal. I see what looks like the link wire, it should have a ring terminal on the other end but it looks in the photo like it goes through a grommet elsewhere. The plug to the alternator normally has two wires under that black outer sleeve, A black/white (live from ignition) and a Red/white (to dash warning light).
- 544565B1-1F6D-4834-9970-8820C636EDAC-1888-000001AA7F5F11C4.jpg (99.75 KiB) Viewed 8376 times
