Rear spot
Rear spot
I want to put one spot on back with switch just to light back when needed ,will I need a relay for 1 spot ??
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Rear spot
One 55w spotlight will only use 4.5 amps so I wouldn't bother with a relay depending upon where your taking the supply from. Did you want this light to work regardless of ignition on/off. Is it for reversing or just a worklight ?
Re: Rear spot
I used a relay when I mounted mine
But I used a switch that matched the existing dash switches
Re: Rear spot
I used to have mine on a relay. I really need to put it back on I always used to use it, will prob just use a 20amp switch without a relay this time though to save on wiring.
Re: Rear spot
Just a work light was thinking straight to battery via switch
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Rear spot
Yep in line fuse it will be
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
