Rear spot
Crisdolf
Rear spot
Post by Crisdolf » Sun Oct 28, 2012 5:01 pm
I want to put one spot on back with switch just to light back when needed ,will I need a relay for 1 spot ??
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Rear spot
Post by Darrell » Sun Oct 28, 2012 5:14 pm
One 55w spotlight will only use 4.5 amps so I wouldn't bother with a relay depending upon where your taking the supply from. Did you want this light to work regardless of ignition on/off. Is it for reversing or just a worklight ?
Re: Rear spot
Post by Tramp » Sun Oct 28, 2012 10:58 pm
I used a relay when I mounted mine
But I used a switch that matched the existing dash switches
Re: Rear spot
Post by ScottieJ » Mon Oct 29, 2012 6:29 am
I used to have mine on a relay. I really need to put it back on I always used to use it, will prob just use a 20amp switch without a relay this time though to save on wiring.
Crisdolf
Re: Rear spot
Post by Crisdolf » Mon Oct 29, 2012 6:32 am
Just a work light was thinking straight to battery via switch
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
Re: Rear spot
Post by ScottieJ » Mon Oct 29, 2012 6:36 am
Don't forget a fuse ;)
Crisdolf
Re: Rear spot
Post by Crisdolf » Mon Oct 29, 2012 6:38 am
Yep in line fuse it will be :)
Sj413 Vx 1986
2" lift
30mm Spacers
215x15
Inner roll cage
Winch
Driven with a Smile
