Can anyone translate "girl" to english
Post by dan_2k_uk » Fri Mar 09, 2012 12:25 am
Mrs just came home saying the brakes on her mk3 golf intermitently feel like bubble wrap.
I took it for a 10 min spin and they feel spot on to me.
She says its only when braking gently so thats the ABS ruled out.
Apparently it makes a ticking sound and the pedal steps down in sync (hence the bubble wrap I guess)
Dan
Highlander
Re: Can anyone translate "girl" to english
Post by Highlander » Fri Mar 09, 2012 12:00 pm
I wouldn't rule out ABS, sounds like thats what it is.
I had a similar problem on my Sierra recently, ABS actuating under very light braking when coming to a stop (under 10mph).
Turned out to be a dirty ring sensor on one of the front wheels.
and according to the manual its not even supposed to work at low speed! :lol:
Highlander
Post by Highlander » Fri Mar 09, 2012 12:13 pm
p.s. an ex girlfriend of mine arrived home one night complaining about a steering problem...
Went outside and found one of these on the rear :hahaha:
Post by Tramp » Fri Mar 09, 2012 1:16 pm
Highlander wrote:I wouldn't rule out ABS, sounds like thats what it is.
Snap, my old smart car did the same, it was fine braking from speed bit less than 20mph the brake peddle used to judder, it turned out the reluctor rings (abs rings) had cracked & split on the rear. Smart cars were pretty notorious for it (when I started looking) & it was mostly due to corrosion on the drive shafts,
Post by dan_2k_uk » Fri Mar 09, 2012 1:24 pm
I have tried my hardest to explain to her what abs feels like and she seems to think it isnt. Will have a look later though
Dan
Highlander
Post by Highlander » Fri Mar 09, 2012 1:41 pm
Easiest solution is probably a new girlfriend :hahaha:
Post by dan_2k_uk » Fri Mar 09, 2012 4:56 pm
Highlander wrote:Easiest solution is probably a new girlfriend :hahaha:
This one lets me store anus parts in the kitchen and fiddle with them in the lounge so she aint going anywhere!
Best get under there and have a look at that ABS!
Post by Edweird » Fri Mar 09, 2012 5:46 pm
The bubble wrap thing to me sounds EXACTLY like ABS.
