nathan.stevens
Post
by nathan.stevens » Sat Dec 10, 2011 6:38 pm
my transfer box was making a horrible noise so i had a quick look and was pretty sure it was the bearing on the shaft behind the transmission brake (output rear) so i ordered said bearing and am going to attempt replacing it tomorrow.
can anyone give any advice on the easiest way to get to the bearing because i haven't got a clue when it comes to transfer boxes if i'm honest!
cheers, nathan
Post
by Darrell » Sat Dec 10, 2011 7:01 pm
Not much help really but here's the workshop manual. Well the 413 anyway,think it's only the gear ratios that are different from the 410.
http://www.4x4.in.th/manual_sj413/chapter14.pdf" onclick="window.open(this.href);return false;
nathan.stevens
Post
by nathan.stevens » Sat Dec 10, 2011 7:10 pm
okay thanks mate, suppose it should be easy to see where everything is when it's off the motor, cheers
- The Boss
Post
by ScottieJ » Sat Dec 10, 2011 7:39 pm
Also have a look at the rocklobster write up in the DIY section of the website, that details how to strip and rebuild the tbox with lots of pics
