LJ80
pro4x4@hotmail.com
LJ80
Post by pro4x4@hotmail.com » Mon Nov 21, 2011 7:22 pm
Hi guys,
Does anyone know anything about engine swaps for LJ80s.. Ive jut bought one and the 800cc is knackered.. Whats the best swap or options available?? Thanks for any advice that comes my way..
rgonzobull
Re: LJ80
Post by rgonzobull » Mon Nov 21, 2011 8:21 pm
Hi and welcome to LJ80 world. SJ410 engine bolts straight straight up to gearbox. Swap oil pick up pipe and sump over from lj engine onto sj. Use the lj clutch and flywheel. Also swap the distributor and housing over from the lj to the sj and i think thats it from memory. If you get a santana sj410 engine you will need to just shave a few millimetres off the gearbox input shaft due to spigot bearing on engine being smaller. If you need any more info let me know. A good site for info is http://www.lj10.com" onclick="window.open(this.href);return false;. Hope its ok to post this link.
LJ80Q
Re: LJ80
Post by ScottieJ » Mon Nov 21, 2011 10:05 pm
:welcome2: to :suzuki:club UK matey, glad you found an lj80 as above the 970cc engine bolts pretty much straight in but people have been known to fit the 1.3/1.6 using a 413/samurai gearbox however that does involve a lot more work. I'm toying with fitting a swift gti 1.3 dohc 16v in mine :guns:
Go on then post some pics up ;)
pro4x4@hotmail.com
Re: LJ80
Post by pro4x4@hotmail.com » Tue Nov 22, 2011 3:20 pm
Cheers guys, thanks heaps for the info.. Ill post some pics in a few days.. Thanks again for the help....
Chris..
pro4x4@hotmail.com
Re: LJ80
Post by pro4x4@hotmail.com » Tue Nov 22, 2011 3:56 pm
Also guys anyone have any 15 x 10 rims to suit?? Looking for something with deep dish and possibly alloy but steel is fine.. Thanks again..
Chris..
Re: LJ80
Post by ScottieJ » Tue Nov 22, 2011 4:12 pm
Just a word of warning 15x10 wheels do like to eat wheel bearings for breakfast :lol:
I do love the look of mine but when it was my daily drive and offroader my sj410 used to go through front bearings every 12 months and rears every 6.
Depending on what your LJ is mainly going to be used for I would perhaps recommend to not go any wider than 8" unless you really must have 10" wide wheels :smokin:
Just got me thinking I might bolt mine up to the LJ just for a laugh next weekend, not sure if 33s will fit with no lift though :lol:
pro4x4@hotmail.com
Re: LJ80
Post by pro4x4@hotmail.com » Fri Nov 25, 2011 1:58 pm
Thanks for the heads up dude!!!
Few mods in the worx so Im sure itll be fine..
So who on here has sprung over an lj80 and what mods have u carried out as far as Idler arm or pitman arm go?? Im well aware of z bars, are there any off the shelf parts available for steering gear as far as the lj goes???? Thanks again......
rgonzobull
Re: LJ80
Post by rgonzobull » Fri Nov 25, 2011 4:54 pm
Not done a springover. But with regards to the steering im currently looking at doing a high steer conversion. I have the mercedes arms that you need to do it. May be worth googling it as it may give you an idea to use it with the spring over. From memory i think that there is a half high steer too. If i find article ill post link on here
LJ80Q
rgonzobull
Re: LJ80
Post by rgonzobull » Fri Nov 25, 2011 4:59 pm
Found the link with the write up just in case it is of interest to you.
http://www.zukiworld.com/forum/general- ... r-my-sami/" onclick="window.open(this.href);return false;
LJ80Q
Re: LJ80
Post by twiss » Sat Nov 26, 2011 12:23 pm
Ahhh nice that's handy, I have a couple of those around somewhere...
