clutch cable
Smalljeep
clutch cable
Post by Smalljeep » Sun May 22, 2011 10:59 pm
i put my clutch cable back on, but it was riding the clutch all the time so when i gear the anus wouldnt move, i took off the handle and cable now it jumps so that eliminates the problem as being the clutch its just the cable.
is there some way to set it up right, just seems a bit fiddly to get it right.
1991 Suzuki Samurai with 1.6 8v engine
2002 Peugeot 406 HDi 110 Executive
Re: clutch cable
Post by twiss » Mon May 23, 2011 10:41 am
I just did the nut on the end of the cable up quite tight...
then adjusted it one way or the other at the bracket where the cable is held onto the engine...
Smalljeep
Re: clutch cable
Post by Smalljeep » Mon May 23, 2011 10:44 am
is there a specific angle you put the handle on at though?
Re: clutch cable
Post by ScottieJ » Mon May 23, 2011 12:47 pm
http://www2.izook.com/?page_id=204" onclick="window.open(this.href);return false;
http://www.acksfaq.com/samclutchadj.htm" onclick="window.open(this.href);return false;
:thumbup:
Smalljeep
Re: clutch cable
Post by Smalljeep » Mon May 23, 2011 2:10 pm
another problem solved, got the cable on right and took the anus out on its maiden voyage.
great site you very helpful people thanks. :thumbup:
