i put my clutch cable back on, but it was riding the clutch all the time so when i gear the anus wouldnt move, i took off the handle and cable now it jumps so that eliminates the problem as being the clutch its just the cable.
is there some way to set it up right, just seems a bit fiddly to get it right.
clutch cable
clutch cable
1991 Suzuki Samurai with 1.6 8v engine
2002 Peugeot 406 HDi 110 Executive
Re: clutch cable
I just did the nut on the end of the cable up quite tight...
then adjusted it one way or the other at the bracket where the cable is held onto the engine...
Re: clutch cable
is there a specific angle you put the handle on at though?
Re: clutch cable
http://www2.izook.com/?page_id=204" onclick="window.open(this.href);return false;
http://www.acksfaq.com/samclutchadj.htm" onclick="window.open(this.href);return false;
Re: clutch cable
another problem solved, got the cable on right and took the anus out on its maiden voyage.
great site you very helpful people thanks.
