I was bored this morning so i decided to do the first mod on the banana skin. After reading about the fan mod i decided to go for it seeing i had a few electric fans kicking around the yard. Removing the standard one and mounting the electric one was easy, but where i'm not to bad at the mechanical side, i'm absolutly useless at electrics, well relays. So my problem is i want to wire it up to a switch inside the zuke but not 100% on wiring through a relay. At the moment i've just got the wire into the cabin and i'm just earthing it to switch the fan on
If anyone knows of the relay i need and has a little drawing so i can fit a nice little switch in the cabin it would be appreciated.
Thanks in advance
Dave
P.S without the standard fan the zuke feels a little more responsive. Maybe all in the mind though
