SU Carb HIF 6 / HIF 44
rooihond
Post by rooihond » Mon Jul 12, 2010 6:48 pm
Hi Guys !
What is the difference between a SU HIF 44 and HIF 6 ?
I recently picked up some "HIF 44" carbs off eBay, but the tag says AUD 521 L and AUD 521 R. As per Rover 3500 SD1
Kind regards,
D
dominic
Re: SU Carb HIF 6 / HIF 44
Post by dominic » Mon Jul 12, 2010 9:27 pm
Hiya matey!
Hows things ?
Long time no see/hear.
As for an answer for your question.. i know nothing about SU Carbs.... sorry.
Dom
8-)
Currently Drive
SJ 410 Q 1985 (GREEN)
VITARA GL+ 2017 (SILVER)
rooihond
Post by rooihond » Tue Jul 13, 2010 4:39 am
Hi Dom !
Still doing great thanks. Like usual been lurking in the background.
I'm contemplating a SU conversion, as my Aisin carb is getting rickety, damn auto choke doesn't work properly any more.
I still adore the little Samurai !
rgds
D
Post by ScottieJ » Tue Jul 13, 2010 9:49 am
hi matey, the hif 6 will probably be too big for an sj and i dont think you'll be able to get a spring and needle set up that will run with the correct air fuel ratio, however i might well be wrong so contact burlen fuel systems for some advice as you might be able to set it up to run on a suzuki as i've heard of them being run on turbo'd mini's.
the common su for 1.3 and 1.6 suzukis is the HIF44 which measures 44mm
dominic
Post by dominic » Tue Jul 13, 2010 2:15 pm
Hey Derek,
I might have a spare Carb ,but it be for a 410.
I dont know if the 410 and 413 carbs are the same, something tells me that they are different.
Do you have a photo of your carb for us to see ?
Anyhow, glad to see you back here, dont go so long without some gossip.
Dom
8-)
Currently Drive
dominic
Post by dominic » Tue Jul 13, 2010 2:20 pm
Oh yer,
Im sure you enjoyed the world cup there in sunny South Africa.
Lucky you.
8-)
Currently Drive
Post by ScottieJ » Tue Jul 13, 2010 3:15 pm
410 carbs are side draught like an SU so wont fit a 413. i doubt they'll provide enough fuel even with an adapter either.
Shame really as they are so much better than the 413 carb!
dominic
Post by dominic » Wed Jul 14, 2010 2:20 pm
Thanks Scottie for the info, great help for some of us who dont know much about carbs.
Dom
8-)
Currently Drive
rooihond
Post by rooihond » Sat Jul 17, 2010 5:01 am
Hi Guys,
Thanks for the replies and offers, got it figured. HIF6 and HIF44 exactly the same. HIF6 non-metric old numbering.
HIF6 is 1 and 6 eighths of an inch or 1.75", which in metric terms is 44mm hence the newer HIF44 numbering.
Yes, World Cup was a bash !
I'm now looking for the air cleaner flange for the SU. Anyone got one lying around ?
Regards to all.
Derek
