Vitara extended front shocks......
1995 Zuk
Post by 1995 Zuk » Thu Jun 18, 2015 10:06 am
Hi, if there is a post about this sorry for repeating, but unable to find, spent ages looking.
Right Question is what other manufacturers front shocks fit on a Vitara? thinking of ones that will give a 3" lift.
Yep I know you can get spacers, but they must have some limits using standard shocks.
Have heard Frontera fit but not found any research to say that.
F.Y.I.
107 rear shocks fit a Vitara a treat, unlike Astra ones no need to drill hole out, or have to make bottom fixing fit snugly. and they are also about an inch longer.
Cheers.
David
2003 GV1600 sport
1995 Vitara SWB
Re: Vitara extended front shocks......
Post by donkeychomp » Thu Jun 18, 2015 10:16 pm
I used GV coils and GV shocks for a 2" lift. Going higher with a Jimnybits lift kit later on...if I ever get the time to fit it!
1995 Zuk
Post by 1995 Zuk » Fri Jun 19, 2015 8:41 am
Cheers Donkeychomp
I have GV springs and shock spacer on already, want to go to 3" now, have spring spacer to go on GV springs so just wondering what front shocks are out there.
2003 GV1600 sport
1995 Vitara SWB
Rhinoman
Post by Rhinoman » Sat Jun 20, 2015 5:42 pm
The spacers work very well. In stock form the struts have around 2" of unused travel with the wishbone hard against the bumpstop, lowering the struts allows all the travel to be used.
