Dumb Question! Where Does This Dislodged Dash Lamp Go Back?
SherwoodNash
Post by SherwoodNash » Mon Jan 12, 2015 11:12 am
As per usual after heavy rain, I was mopping up inside under the dash above fuse box in my 1987 SJ 410 and dislodged the lamp in the pic below. I've tried all circuits and it doesn't light up? and it probably should as it's plastic and doesn't look as though it needs an earth.
I've fumbled around with a mirror and light but no luck, any ideas what it is and where it goes back please?
Thanks!
Re: Dumb Question! Where Does This Dislodged Dash Lamp Go Ba
Post by ScottieJ » Mon Jan 12, 2015 11:13 am
It doesn't look like an original item to me?
Post by turbo-tom » Mon Jan 12, 2015 12:41 pm
Looks like its off and ol 52mm gauge...
SherwoodNash
Post by SherwoodNash » Mon Jan 12, 2015 1:11 pm
Thanks Tom and Scottie for your replies, you're both correct, mystery solved!
The lamp got pulled out of an after market, tow bar electrics, on warning lamp, located on the right hand auxiliary switches panel.
Cheers again!
