Excuse my noob-ness, lol.
I've got a -86 sj413 and it doesn't fire up until I release the key. Is it supposed to be like that? Never seen that on any other car I've had.
When I turn the key the startmotor runs, but no ignition until I relese the key.
Ignition when I release the key?
1986 Suzuki SJ413JX
1987 Suzuki Swift GLX
1973 SAAB Sonett Mk3
1996 SAAB 9000 2.3 Turbo
1975 Puch Dakota 70cc aka. The Angry Wasp
2007 Deutz-Fahr Tractor, my comfiest ride
Re: Ignition when I release the key?
Welcome to the club
I can only assume when in the cranking position the switch is disconnecting the ignition circuit.
Unplug the ignition switch and get the multimeter on it I guess.
- Ladaman
- Suzuki Guru
Don't they also do that sometimes if there just not enough juice in the battery?
Ladaman wrote:Don't they also do that sometimes if there just not enough juice in the battery?
Sounds fair if the battery charge is low, the starter can use it all.
Yep, that must be it. Tried with another battery today and it made no difference.Darrell wrote:Welcome to the club![]()
1986 Suzuki SJ413JX
Have you got a ballast resistor? could be a fault on that circuit.
