Drivers side seat runners, 87 SJ410 Santana
Re: Drivers side seat runners, 87 SJ410 Santana
Post by Darrell » Thu Nov 29, 2012 7:30 pm
Right then, those pics I posted said passenger side on a USA model so I assumed that was the drivers side in the UK, Wrong :oops:
As I can now tell the seats are swapped around as well as the steering wheel :D
So been and had a look at the drivers side rails on mine and there the same as yours (well not broke :D )
Seem a bit rubbish as they are only locked on the one side. There appears to be just one spring (torsion rod) to keep the locking arm in place.
I assume the passenger side is far more complex due to the lever letting the seat fold and slide forward to allow passengers in the back.
Just the one crappy photo taken under the seat so a bit naff...
Fatboy 18
Post by Fatboy 18 » Thu Nov 29, 2012 8:11 pm
Good to meet you Donkeychomp
Thanks for the seat runners, different to mine but I will have a fiddle and see if I can adapt them to fit my seat :)
Post by Tramp » Thu Nov 29, 2012 8:12 pm
Heres my Spanish sammys drivers side seat runners
I bought some Spanish 410 runners to go in but they were different they had a handle to raise the seat or something - weird but totally incompatible!
dazerede
Post by dazerede » Thu Nov 29, 2012 8:34 pm
I don't think I.have a spring in my drivers side runners on my jap 410 and they are the same as darrels pic as they were hard to.slide forward and back so I wacked.a load of grease on it and it helps a bit
4” calmini lift kit :)
Fatboy 18
Post by Fatboy 18 » Thu Nov 29, 2012 8:40 pm
I have to admit I'm just amazed how many variations of seat runners there are! Hardly anything on these SJs seems standardised
Thanks for the pics Darrell and Tramp, Yes they are the same as mine! But now Ive got something different to play with! Post pics soon :)
Post by donkeychomp » Thu Nov 29, 2012 10:44 pm
Yep, good too meet you matey...sure hope you can get that new runner to work ok...I have the others just in case you need any bits.
Ever thought about putting the Viper engine in the Zook? :brows:
Alex
Fatboy 18
Post by Fatboy 18 » Fri Nov 30, 2012 4:05 pm
Right then, update Had a rummage around under the rear seats and found that Torsion wire!
I thought that had fallen off the base of the seat somewhere :(
The seat runners I picked up from Donkeychomp are a different set up all together. On the Spanish built SJs the rear bracket is actually already welded and part of the Bodywork.
On the seat runners I picked up the rear bracket is attached to the seat runners and then you bolt that to the floor pan. Also the adjuster lever moves up and down, where as on the Spanish built SJs its a twisting motion with that thin wire holding the seat in place :(
Going to have to do some head scratching to see if I can make the later ones fit, but it may raise the seat in order to get the adjuster working!
