Drivers side seat runners, 87 SJ410 Santana
Fatboy 18
Post by Fatboy 18 » Sat Nov 24, 2012 3:13 pm
Looking for advice or a diagram or picture of how the stock drivers side seat runners are supposed to work?
The drivers seat runner next to the transmission tunnel had snapped in half and the seat runner on the other side of the seat (the one with the adjuster lever) seems to have no spring on the adjuster lever. You can just flip the arm and the seat will slide forward and back no problem, so hitting the brakes the seat would slide forward and accelerating the seat would slide back! :er:
I can get the broken seat runner welded up ok but i'm sure there should be some sort of spring to hold the adjuster lever in the locked position?
Thanks.
Anyone know if there is a pdf parts file for a SJ410 Santana 1987 ?
Re: Drivers side seat runners, 87 SJ410 Santana
Post by Darrell » Sat Nov 24, 2012 4:20 pm
This is the best I can do, photo's nicked off ebay and stitched together (if you see the slight misalignment ;) )
Seat rails.jpg (152.47 KiB) Viewed 7701 times
Fatboy 18
Post by Fatboy 18 » Sat Nov 24, 2012 6:15 pm
Brilliant, that's exactly what I needed to see, Thanks. :)
Looks like I've got some bits missing!
Post by donkeychomp » Sat Nov 24, 2012 10:59 pm
I think I have some runners knocking about in the garage, will have a look later, you are pretty close to me so if you want them you are more than welcome to have them.
Alex
Fatboy 18
Post by Fatboy 18 » Sat Nov 24, 2012 11:32 pm
That would be great, thanks very much :hands:
Post by donkeychomp » Sun Nov 25, 2012 2:56 pm
No worries, will check for you tomorrow but I'm pretty sure I have a pair.
Post by donkeychomp » Mon Nov 26, 2012 7:00 pm
Found 2 runners in amazingly good nick. Let me know when you want to pick them up.
Fatboy 18
Post by Fatboy 18 » Mon Nov 26, 2012 8:32 pm
Brilliant, Could do anytime this week or weekend?
Fatboy 18
Post by Fatboy 18 » Wed Nov 28, 2012 11:10 pm
Heres a pick of my current seat runners. This is all I have, no springs cross link wires or anything!
http://www.flickr.com/photos/90582394@N02/8228486562/
Post by Darrell » Wed Nov 28, 2012 11:36 pm
Different rails altogether to what I posted at the weekend :er:
Going to need a bit more checking out :S
I only robbed those pics off ebay because it was pi**ing down with rain :oops:
