Dropping the SJ
Dropping the SJ
My SJ is on lift shackles from previous owner - I don't think they're necessary and as you all know they have various downfalls...
So where can I get standard shackles, or do I just do away with the shackles altogether?
Also, what do I need to watch out for when doing the switch?
- timwilks13
- SCUK Website Padawan
Re: Dropping the SJ
You can't do away with shackles as they're the bit that allows the spring to flex. Swapping back to standard is easy, just two bolts.
Re: Dropping the SJ
Where might I get a set of standards?
Re: Dropping the SJ
I was just about to throw a set of standards in the scrap bin.
You can have them for the cost of postage if you like?...
- Ladaman
- Suzuki Guru
Re: Dropping the SJ
My son's got a set you can have. If you go to Tong he can give them to you there.
Re: Dropping the SJ
Tong, Bradford?Ladaman wrote:My son's got a set you can have. If you go to Tong he can give them to you there.
Re: Dropping the SJ
Any idea what postage might be? They won't be light!AndyD wrote:I was just about to throw a set of standards in the scrap bin.
- timwilks13
Re: Dropping the SJ
They're quite small are standard shackles, hardly weigh a thing.
- Ladaman
- Suzuki Guru
Re: Dropping the SJ
Yep.AntD wrote:Tong, Bradford?Ladaman wrote:My son's got a set you can have. If you go to Tong he can give them to you there.
We will be there from about 10.
