Engine Rebuild Parts
Has anyone on here done a full engine rebuild?
I currently have a 1.6 (G16A) in pieces ready to rebuild, but my local garage (run by a friend of mine) is struggling to find the parts I'm after. All they can definitely get so far is the full gasket set, timing belt and accessory belts.
But I'm also in need of;
Main Bearing Shells
Thrust Bearings
Big-End Bearing Shells
Piston Rings
Anyone obtained these before?...
Main Bearing Shells
Thrust Bearings
Piston Rings
- dominic
- Can I have a tow
Re: Engine Rebuild Parts
Hi Andy,
I have done a full engine rebuild, but only on a F10A engine. that was 10 years ago.
I have no idea about the G16A engine.
I cant help you matey, sorry , but im sure someone here can.
Dom
Dom
Currently Drive
SJ 410 Q 1985 (GREEN)
VITARA GL+ 2017 (SILVER)
Cheers Scottie! I'll give them an e-mail...
- mike harris
- SCUK is my life
I've got a calmini rebuild kit I'd sell for the right money?
Thanks for the offer mike, how much is the right amount? Though I wouldn't need the pistons and pins if it's the full kit you have.
This is the reply I got from Kar Engines;
Hi Andy,
Thank you very much for your enquiry regarding the engine parts you require for the G16A.
Prices as off below;
HEAD SET UDS601 £28.50
CONVERSION SET (BOTTOM END) £18.00
TIMING BELT UTB4170 (NO KIT AVAILABLE NOW) DAYCO BRAND £12.50
BIG END BEARINGS £28.50 (ENGINE SET) CR4056
MAIN BEARINGS £44.00 (ENGINE SET) MB5587
THRUST WASHERS £8.00 (ENGINE SET) TW144
PISTON RINGS CHOICE OF LAYOUT £65.00
The head set, conversion set and timing belt are available ext stock but the other items I can get for you are special order and non returnable.
All prices are plus vat and carriage charge of £6.50.
Best Regards Darren
Kar Engines
So it seems they can get me what I need at £252 total.
Could you better that mike?
And might it matter the size of parts you have?
According to Haynes I need the main bearings in Std Sizes; 2x Yellow, 3x Colourless, big ends and piston rings would be Std size.
Hi Andy,
Best Regards Darren
Kar Engines
Glad they could help matey! And thanks for posting up the prices that's really handy as I have a few 1.6 8vs that could do with a rebuild!
- mike harris
- SCUK is my life
Il speak to Paul
- mike harris
- SCUK is my life
Andy,
£200 mate
Pistons, rings, big ends, mains, rings, and performance long duration cam
And head gasket.
£200 mate
And head gasket.
- image.jpg (73.54 KiB) Viewed 7803 times
- dazerede
I'm also rebuilding a g16 8v engine but only dong head gasket water pump and a few other goodies won't be doing piston rings or that sort of stuff
- image.jpg (1.99 MiB) Viewed 7790 times
4” calmini lift kit
4” calmini lift kit
