Rear Light Problem
Rear Light Problem
Hi guys, I finally got round to putting my new rear lights on my SJ413 yesterday oly to find I have a problem, no reverse and no p/s side indicators, (front or back), although the hazards work on both sides.......bought the lights off a british seller on e-bay or amazon but I presume they came from abroad, (I've bought that much recently I'm not sure where I got these from haha, will have to dig the paperwork out). Can anyone give me a clue where to start with sorting the problem out?, my SJ is Japanese is there a possibility the lights would be wired for Spanish models?
Re: Rear Light Problem
do the wiring colours match up at the plugs? if so, I would think it doesn't matter if it's spanish or jap.
The spanish lights will have a built in foglight on the drivers side, the jap lights have no fog light and a reverse light on both sides
On the standard spanish lights there is a shared earth bar across the bulb holders, the jap have individual earth wires to each bulb holder... but they could be different if they are aftermarket
cheers guys, looks like they're Jap then, I've got the wiring diagram so will try and suss it out but if not will have to get a spark in
Have you swapped the units over to test if its a faulty cluster?
- Sj410red
My Spanish santana doesn't have built in fog light it has double reverse lights and separate fog light, is that not standard then Twiss?
3" calmini lift springs
6" shackles
Rough Country Shocks
Z bar
32mm spacers
Aisan free wheeling hubs
Roll bar
Snorkel
K&N air filter
Poly bushes all round
Front Diff guard
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
- donkeychomp
If you are in a rush to get them sorted ignore the reversing light...it's not needed for an MOT.
Its spanish regs that they should have a foglight so I'm not sure they may have been changed previously? Good call if they have LOL spanish lights are crapSj410red wrote:My Spanish santana doesn't have built in fog light it has double reverse lights and separate fog light, is that not standard then Twiss?
What reg is your 410?
- Sj410red
Mines a g reg 1988
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
6" shackles
Z bar
32mm spacers
Roll bar
Snorkel
K&N air filter
Front Diff guard
cheers guys, time to get a spark in methinks
