If the distributor has been turned may have altered timing. If all the.marks line up easiest way to do it is with a timing light.george123 wrote:Okay cuz the timing was only done 8000 miles ago how would I know if the timing was out when I line the marks up?
Won't start
Re: Won't start
Re: Won't start
My starter is fine it's just not fiering
Re: Won't start
Il have a look because it wants to start would dirty fuel stop it from starting
Re: Won't start
Dirty fuel shouldn't be too much of an an issue unless it has blocked the carb up.
Have you tried blowing down the carb fuel in pipe yet?
Re: Won't start
Not yet I'm going to see if all fuel pipes are clogged and clean the carb out tomorrow but I tried easy start dint work
Re: Won't start
So close to the old girl starting all it is is the dizzy cap needs rotating slightly
Re: Won't start
It's a timing issue then. Just a case of have someone turn it over while you turn the dizzy till it fire.george123 wrote:So close to the old girl starting all it is is the dizzy cap needs rotating slightly
If it fires with the dizzy all the way to one side might be an to check the timing belt markings are all set correct and if they are pull the dizzy out and rotate it a tooth.
Re: Won't start
Naa it wants to fire when I turn it towards the middle but it's really hard because it's just so hard to get it in the right position haha but I got it cough it to life for like a second then I knocked it by accident haha
- Edweird
Re: Won't start
Yeah, certainly sounds like it's just a spark timing issue. Get yourself an extra pair of hands and have a play.
Re: Won't start
Hopefully today but it's just I can't get it smack on so it runs over an runs haha
