Throttle Sensor set up
Hello All
Does anyone know how to set up the TPS on a 1997 16v vitara,
The engine started to run lumpy and the TPS fault light came up so I bought a new one but then I've been told you need to set this up? me and electrics aren't friends so I have no idea what to do!
Re: Throttle Sensor set up
Anybody got ideas how to set this up, I really do hate electrics
Checked my vitara manual and my grand vitara manual and it says nothing about setting it up
Some of the pictures (depending on make of TPS) do show the fixing holes slightly slotted, so I guess you can rotate it a little ??
Well I kept searching and found this lot. http://www.fixkick.com/sensors/tests/TP ... html#MYWAY
Thank you very much for finding that, least it does show that you must set it up..................but its going over my head a bit
I did take the TPS totally off so it will need a full set up but I cant see where it says what to do if you have taken it off, only how to set it up if its still attached.
Right, read it about 5 timers now so think I get it! will try tonight and see what happens
Thanks mate
Thanks mate
Soooooo had a bash and managed to get it so the light goes off once you rev it, any ideas why this would happen?
As I need a feeler gauge thingy to set this up righ I decided to carry on with another job I have to do for the mot, fit the cat back on. Once I fitted the cat and tried the engine to see if there were any leaks I my weld, the engine now starts to cut out when you rev it.
I will try and set it back up tomorrow again
What are you using to set it up? have you got a throttle opener on that? if you have it needs to be fully retracted.
Hi mate, I've tried to follow the link and use a feeler gauge but its all over my head.
Right I give up,I've got no idea what I'm doing, it seemed to be running fine last night until I put the cat back on. Now it just dies when you touch the accelerator.
Does anyone know what they are doing with these sort of problems, I will pay you as I'm about to pick up the yellow page to find a auto electrician.
- donkeychomp
