Rear view mirror
Rear view mirror
Hi,
I removed the rear view mirror whilst I was trying to find out why the sunroof wasn't working, and now I can't work out how the damned thing stays attached to the roof, It has two massive holes, presumably for the bolts, but whilst I have screws that screw into the threaded holes in the roof none of them will keep the mirror in place as their heads aren't big enough, am I missing a pair of washers or something?
Damned Haynes manual is no use whatsoever (typical)
someone please answer, cos she needs an MOT!
Re: Rear view mirror
I have no idea about the mirror fitting. What I do know is that you dont need it for an MOT.
- turbo-tom
Go to your local fixing place and get some washers. Failing that im sure Darell will have a diagram for it.
Tom
Ford Fiesta ST
Ford Fiesta ST
thanks for replies!
Thought interior mirror was an MOT fail?
Problem is it would need 2 much longer bolts. will go have a dig in my box of bolts........
strange that the bolts would have a small thread (5mm?) whilst the mirror mounting holes are nearer 13mm..
If its anything like the SJ they have these small plastic cone things that the screws sit in.
Well it shows a plastic cover............
- Untitled.png (100.13 KiB) Viewed 6923 times
- donkeychomp
If you are desperate you could buy a universal one with a suction cap, think every motor factor will have them.
there is 2 plastic bungs that go in the holes then screws go through them
thanks for the replies, I can't find the bungs (must have put them somewhere "safe" so as to not lose them). but have managed to use a pair of longer bolts and large washers for now.
