Quick timing question!
Xoquin
Post by Xoquin » Wed Jun 19, 2013 1:25 pm
I have a 413 with an su carb on Rockwatt manifold. The sj seems down on power, doesn't really like hills and tops out at 50mph. I'm running a rocklobster if that makes a difference. By looking at previous posts, I'm led to believe this is a timing issue, so
1, is it a timing issue?
2, what should the timing be with my setup? Is it the same as a standard carb??
Thanks, Neil
Re: Quick timing question!
Post by Tramp » Wed Jun 19, 2013 2:34 pm
I'll be honest, I'm running a weber with a rocklobster and top speed is about the same, when i took it on the motorway lorries were over taking me! What size tyres have you got?
Post by dan_2k_uk » Wed Jun 19, 2013 2:38 pm
Mine is running well with standard timing on a 1.6.
How well tuned is the carb? What needle and spring are you running?
Xoquin
Post by Xoquin » Wed Jun 19, 2013 2:56 pm
Thanks for the replies!
I have a BDL needle & red spring
Tyres are 235/75 15's. I was hoping to go to 31"s but am a bit reluctant now if that's all the power i'm going to get.
Post by ScottieJ » Wed Jun 19, 2013 3:00 pm
What is your timing set at? Was it set with the idle at the correct speed, the vacuum advance disconnected and blocked off?
Xoquin
Post by Xoquin » Wed Jun 19, 2013 3:22 pm
I definitely blanked the vac advance off. I think the timing was 10 degrees and the idle was around 800
Post by ScottieJ » Wed Jun 19, 2013 4:02 pm
As long as there's no pre-ignition that should be fine :er:
Maybe the mixture is out, should easily be able do over 50mph on that size tyre.
Post by Tramp » Wed Jun 19, 2013 7:52 pm
Mines on 235/75r15 too, I thought my issue was that I needed bigger tyres, the gearing is too low for what I do, i was going to put my original transfer box back in, maybe mine has a running issue too?
Rhinoman
Post by Rhinoman » Thu Jun 20, 2013 12:37 pm
Have you checked that it advances correctly when revved?
Xoquin
Post by Xoquin » Tue Jun 25, 2013 11:25 am
Turns out timing & mixture were fine. 6 month old spark plug with < 500 miles on it was knackered.
Runs much better now, but good to know it'll still do 50mph on 3 cylinders!
Thanks for the help though
