my little project
- stevepsj413
my little project
Just bought half an sj, the other half was victim of the rust demon, thought it was time i learnt to weld! A few pics of my progress so far, not the neatest of jobs but it should be strong.
- gettin there but still not finished yet, 5kg of welding wire n a 9kg argon gas bottle later
- DSC_0091.jpg (342.27 KiB) Viewed 6376 times
- DSC_0090.jpg (305.86 KiB) Viewed 6376 times
- DSC_0088.jpg (428.1 KiB) Viewed 6376 times
- DSC_0087.jpg (380.73 KiB) Viewed 6376 times
- 1.2mm thick galv steel
- DSC_0086.jpg (418.69 KiB) Viewed 6376 times
- DSC_0079.jpg (420.63 KiB) Viewed 6376 times
- DSC_0077.jpg (604.76 KiB) Viewed 6376 times
- in with the new
- DSC_0078.jpg (559.46 KiB) Viewed 6376 times
- out with the old
- DSC_0069.jpg (483.87 KiB) Viewed 6376 times
- cut the old rusty bits out and braced the sides
- DSC_0056.jpg (530.45 KiB) Viewed 6376 times
- DSC_0043.jpg (523.81 KiB) Viewed 6376 times
- can you see wots missin
- DSC_0042.jpg (555.38 KiB) Viewed 6376 times
- not so from the back
- sj.JPG (89.67 KiB) Viewed 6376 times
- doesnt look bad from the front
- sj1.JPG (81.91 KiB) Viewed 6376 times
- donkeychomp
Re: my little project
Welcome! And some very nice work there, glad to see another SJ saved from the scrap heap. If you get stuck you are in the right place, just ask
Looks good mate Keep it up. Any mods planed
- stevepsj413
its already got shackle lift n swivel hubs, bigger wheels and shockers off a ford maverick on it, just cant wait to get it mot'd and get off road n show them landys how its done! but got big plans for it, snorkel, roll cage, runs like a washin machine full of bricks at moment but im sure i can sort that, bit of wd40 and an oily rag maybe
to the club. Keep up the good work .
nice work, looks like you learnt to weld pretty well. are you going to put any bracing under that rear floor to prevent sagging and vibrations?
Welcome to SCUK.
All i can say is i hate your fab work, its soooo nice and tidy. Damn you.
Lools like you've done a good job boss, nice to see another rotter revived.
some nice work
Hi and welcome.
Looks tidy. As said that floor will probably rattle and vibrate a lot without bracing. Unless its sat straight on the rubbers on the chassis but even then it will vibrate.
