Lets get the ball rolling !!
Re: Lets get the ball rolling !!
Get it couriered £16+vat.
http://www.carpartcouriers.co.uk/acatal ... Parts.html
If the wing is in good condition thats a decent price, even including the courier.
Ollie haven't you got a good wing on the 410? Why not swap it over onto your good SJ then put the crap wing on the other SJ, doubt someone would really care about a rusty wing when they buy it and the rest of it is covered in dents anyway
Problem solved and no cost involved
Even if it's a bit dented, a bit of wood, a hammer, and you can usually make the job...ScottieJ wrote:Ollie haven't you got a good wing on the 410? Why not swap it over onto your good SJ then put the crap wing on the other SJ, doubt someone would really care about a rusty wing when they buy it and the rest of it is covered in dents anyway
...Much, much worse...
On that subject Anton, as much as dents may look unsightly i leave them well alone. Far too easy to make it worse and i'm only gonna put more in again.
Ollie,
what does the other one actually need doing to it
new battery and a load of wiring.
new starter as we nicked the other one
at some point I will come up again and weld up the wing you have on there
it won't be pretty but I can make it solid enough
ill do it in exchange for some of those samurai bits you have.
I will see as well if I can point you in the right direction with the other one as well.
if you can get that one to a driveable condition then it will be much easier to sell it
you've got a load of parts for it so I'm sure we can sort something out.
Parts for labour! Like it, true mechanic pimping yourself out for bits!
I thought we decide that wing had had it ??
Sure Twiss can botch it. Bit of weld, plate and filler.
The problem with it is that is so rotten that when you open the door the whole wing flexes
