Lets get the ball rolling !!
Re: Lets get the ball rolling !!
Post by Jordi » Sun May 19, 2013 8:30 pm
Get it couriered £16+vat.
http://www.carpartcouriers.co.uk/acatal ... Parts.html
If the wing is in good condition thats a decent price, even including the courier.
Post by ScottieJ » Sun May 19, 2013 8:34 pm
Ollie haven't you got a good wing on the 410? Why not swap it over onto your good SJ then put the crap wing on the other SJ, doubt someone would really care about a rusty wing when they buy it and the rest of it is covered in dents anyway :lol:
Problem solved and no cost involved :thumbup:
Post by Anton » Sun May 19, 2013 8:50 pm
ScottieJ wrote:Ollie haven't you got a good wing on the 410? Why not swap it over onto your good SJ then put the crap wing on the other SJ, doubt someone would really care about a rusty wing when they buy it and the rest of it is covered in dents anyway :lol:
Even if it's a bit dented, a bit of wood, a hammer, and you can usually make the job...
...Much, much worse... :hahaha:
Post by Jordi » Sun May 19, 2013 8:52 pm
On that subject Anton, as much as dents may look unsightly i leave them well alone. Far too easy to make it worse and i'm only gonna put more in again.
Post by turbo-tom » Sun May 19, 2013 8:54 pm
Dents are just scratches with a better story.
Post by twiss » Sun May 19, 2013 9:19 pm
Ollie,
what does the other one actually need doing to it
new battery and a load of wiring.
new starter as we nicked the other one
at some point I will come up again and weld up the wing you have on there
it won't be pretty but I can make it solid enough
ill do it in exchange for some of those samurai bits you have.
I will see as well if I can point you in the right direction with the other one as well.
if you can get that one to a driveable condition then it will be much easier to sell it
you've got a load of parts for it so I'm sure we can sort something out.
Post by Jordi » Sun May 19, 2013 9:33 pm
Parts for labour! Like it, true mechanic pimping yourself out for bits!
OllieSJ
Post by OllieSJ » Sun May 19, 2013 9:37 pm
I thought we decide that wing had had it ??
Post by Jordi » Sun May 19, 2013 9:39 pm
Sure Twiss can botch it. Bit of weld, plate and filler.
OllieSJ
Post by OllieSJ » Sun May 19, 2013 9:41 pm
The problem with it is that is so rotten that when you open the door the whole wing flexes
