Propper country build (turf the sj)
Re: Propper country build (turf the sj)
Post by andyrew » Fri May 17, 2013 12:59 pm
:doublethumbs:
maxlee
Post by maxlee » Fri May 17, 2013 8:56 pm
thanks guys i'll find out how much a new one is 2moz and try to get over to the other sj and see if thats any better.. as i'll pinch it off that and fit new one to the other sj as its going on road mot etc
to day i got a little involved and finished (well almost) the fan set up
Hench
gauges just set up to check things will install one neatly tomorrow
i know its a oil temp gauge but it was free and dose the job this is temp of the engine
this is rad temp gose up to 85 when stat opens then back to 70 with fan on low speed on high i can take it down to 60
both temps anus had been running for the time it took to make and smoke a fag and make a tea :thumbup:
do these engines last with the stat taken out :er: i no in other carsi have delt with (bmw) it makes cold spots and can damage heads/reduse flow in certen parts
and final pic i clean the rad fins out this is 25% of what i got out 15% i think i breathed in :yuk: and the rest went up in the air
should make an improvment goes to show high powered hose don't always work :lol:
Post by andyrew » Fri May 17, 2013 9:23 pm
I think a whole new tie rod would be a small fortune or un obtainable.
I think the one on the 410 im breaking is good. Ill check for you tomorrow.
Post by twiss » Fri May 17, 2013 9:40 pm
mike harris will have a tie rod
Post by Darrell » Fri May 17, 2013 10:04 pm
The only company I know selling them :thumbdown:
http://www.euro4x4parts.com/parts/dro11 ... joint.html
Well apart from Suzuki..
maxlee
Post by maxlee » Sun May 19, 2013 11:27 am
dam these ain't cheap ow's me £400 already :cry: know it sounds tight but i wont be spending any more on it i do have a good welder mate tho and some car bits kicking about so the bar might get modded lol unless one comes up cheap.
had a play yesterday diff/box oils changed pumped the tires up dropped it on the floor and
https://www.facebook.com/photo.php?v=48 ... =2&theater its alive :thumbup:
also no good being called turf when the turfs gone so
grass seeds and soil
watered
sorted :thumbup:
Post by Jordi » Sun May 19, 2013 11:29 am
Ha ha, yeah don't want that grass dying off now mate b
Post by Darrell » Sun May 19, 2013 12:55 pm
Put an ad in the wanted section, I'm sure somebody must have some spares. PM mike he's always pulling them apart.
Tie rod keeps being mentioned :er: but I think it's the drag rod your after.
Just make sure you get the right length :thumbup:
May be worth measuring as old Suzuki's have often been messed with..
maxlee
Post by maxlee » Sun May 19, 2013 4:14 pm
its defo the drag link its the ball joint on the end looking at that pic i could get a tie rod and mod that to fit..
went out and bought a disco for my mate yesterday for 950 new 16 inch chunky wheels moted for ages lifted winch bumper etc makes me think what am i doing lol roll on pay and play day next month and i'll get to see what these beasts are like :doublethumbs:
the grass is a way of giving back to the envorioment :smokin:
