Richie
Post
by Richie » Wed Feb 27, 2013 8:43 am
Finally got the G16A engine and gearbox bolted in but the dizzy cap just hits on the bulk head.
Before i get out the BFH
i just wanted to make sure ive not done anything stupid. Anyone else had a issue with theirs being alittle close at the back?
Also the prop that runs from the gear box to the transfur box i think was a 413 and was about 1/3 inch to long so ive had to use the slightly shorter 410 one which went in lovely, just thought i would point these things out as not seen anyone mention they had a issue with them in any other conversion builds.
Post
by dan_2k_uk » Wed Feb 27, 2013 9:04 am
If it is an early 410 I seem to recall the rear gearbox crossmember is slightly different. Maybe causing your engine to sit further back and foul bulkhead and require shorter prop.
Richie
Post
by Richie » Wed Feb 27, 2013 6:51 pm
its a E reg if that helps?
- The Boss
Post
by ScottieJ » Wed Feb 27, 2013 11:02 pm
That should have the later gearbox mount so that's a bit odd, did you mount it up a standard gearbox mount and then do the engine mounts? Maybe a few pics of everything would help us see what's going on, the dizzy shouldn't foul the bulkhead
should be at least 1" clearance.
Richie
Post
by Richie » Thu Feb 28, 2013 8:39 am
The engine and box were to hard to lift together so i seperated them.
First lifted the engine and sit in it place and bolted down the n/s (standard) engine mount.
Then i rested the engine down on the o/s half complete engine mount, the gear box at this point just about lined up with the gear box mount. So i bolted this down then put the spacer in for the o/s mount and bolted that down.
The only thing that was abit unexpected was the o/s mount would of sat way to high and was nowhere near going to line up so i turned it upside down? It was then alot closer.
If anyone has a couple of pics of their mount? maybe im doing it completly wrong...
Still doesnt explain why i had to use the slightly shorter prop, unless everyone has to?
Post
by dan_2k_uk » Thu Feb 28, 2013 11:56 pm
Think both mounts nees modding for a 410. Think its just 1300 mounts that line up.
Might be wrong.
Richie
Post
by Richie » Fri Mar 01, 2013 11:13 pm
Ok this is my n/s mount (this is how it was bolted to the engine in my other truck) plz correct me if its wrong
- DSCF3117.JPG (684.42 KiB) Viewed 7142 times
Richie
Post
by Richie » Fri Mar 01, 2013 11:15 pm
This is the o/s mount layed in place with i think 1 bolt holding it inplace (this one im not sure about)
- DSCF3118.JPG (577.35 KiB) Viewed 7141 times
Richie
Post
by Richie » Fri Mar 01, 2013 11:16 pm
o/s mount again (i think the bracket i put on upside down)
- DSCF3120.JPG (533.25 KiB) Viewed 7140 times
Richie
Post
by Richie » Fri Mar 01, 2013 11:18 pm
This is the gear box mount
- DSCF3135.JPG (593.25 KiB) Viewed 7138 times
