1985 SJ Radiator
Re: 1985 SJ Radiator
You wont be able too just shove the hose in. The stat only opens at high temps. You will have to remove it first.
ok I will consult haynes to where that it is, thank you
The top hose goes into the inlet manifold. Where it goes in, you will see 2 bolts. Un do them, pop the little thing out with the spring. Thats the stat.
