Super413
![Got muddy boots Got muddy boots](./images/ranks/rank1.png)
Post
by Super413 » Sat Jul 04, 2009 3:34 pm
hi,
Im looking to replace my radiator, due to general age and some damage.
Are there any variations in type of radiator that can be fitted?
Also I assume I should flush out the coolant system before fitting a new rad, what is the best practice for this??
thanks
tim
Henry
- Suzuki Guru
![Suzuki Guru Suzuki Guru](./images/ranks/rank6.png)
Post
by Henry » Sat Jul 04, 2009 3:41 pm
What is it going into?
the 410 and 413/sammy rads differ.
Henry
Super413
Post
by Super413 » Sat Jul 04, 2009 4:32 pm
sorry Sj 413
Henry
- Suzuki Guru
Post
by Henry » Sat Jul 04, 2009 4:38 pm
Your going to need one from either the 413 or sammy. This is because they are double core and the 410s are single core and narrower.
Henry
bourneyo
- The Boss
![The Boss The Boss](./images/ranks/rank11.png)
Post
by bourneyo » Sun Jul 05, 2009 12:25 am
yea you will need a 413/sammy rad, some burk fitted a 410 rad to my sammy and it kept overheating!
Dan
![Cool 8-)](./images/smilies/icon_cool.gif)
dominic
- Can I have a tow
![Can I have a tow Can I have a tow](./images/ranks/rank3.png)
Post
by dominic » Sun Jul 05, 2009 11:26 am
Hiya,
As above ....
Very simple job to do on the old SJ's.
Dom
Currently Drive
SJ 410 Q 1985 (GREEN)
VITARA GL+ 2017 (SILVER)
Henry
- Suzuki Guru
Post
by Henry » Sun Jul 05, 2009 11:59 am
Remember not to let the engine run too cool by using a rad too large. This can increase engine wear. The normal opperating temp of the engines are about 90 deg.
Super413
Post
by Super413 » Sun Jul 05, 2009 5:07 pm
Thanks people, I was planning a strainght swap, but just wondered if someone had found rads of other models of cars/trucked suited better.
How do you recommend flushing the water system?
Henry
- Suzuki Guru
Post
by Henry » Sun Jul 05, 2009 9:42 pm
If i wanted to flush it i would shove a hose pipe down the top hose and turn it on. However i have removed my thermostat. What you need to do is rake the round cap off (2x12mm bolts) off the top hose on the inlet manifold, pop the stat out, and shove the hose in. However you shouldn't need to flush it in all honesty.
Super413
Post
by Super413 » Sun Jul 05, 2009 10:50 pm
Thanks for the tips, will just stick a hose in and flush it thorough!
These are all jobs im planning for when im back in the UK in august!
