su carb help!!!!
Re: su carb help!!!!
Post by Darrell » Sat Dec 22, 2012 6:00 pm
Can you get some info on the pump first, make, model, any numbers you can find.
jake 52
Post by jake 52 » Sat Dec 22, 2012 6:40 pm
well wont be able to get to it for the next few days as its down my mates and hes now locked up for christmas
jake 52
Post by jake 52 » Sat Dec 22, 2012 7:43 pm
anyone know how to turn the pressure down on the eletric pump?
Post by ScottieJ » Sat Dec 22, 2012 7:49 pm
You can't turn the pressure down however you can fit an in line pressure regulator but they aren't the most reliable things! Do you not have the original mechanical fuel pump still? Why not just use that if you have?
jake 52
Post by jake 52 » Sat Dec 22, 2012 9:31 pm
Ok, I bought it as it is thought it came out the factory like it lol
jake 52
Post by jake 52 » Sun Dec 23, 2012 5:02 pm
so would it be ebst to fit a mechanical fuel pump? if so where would i get one from?
Post by ROBBIE » Sun Dec 23, 2012 5:52 pm
I got a couple of 1.3 mech pumps
Post by Darrell » Sun Dec 23, 2012 8:03 pm
Sorry to sound dumb but what did you have on it before the SU, as it is a later model.
I've just read some other posts and it's a 95. Not using the injection pump are you :er: :er:
jake 52
Post by jake 52 » Sun Dec 23, 2012 8:48 pm
it had the auto choke carb, i believe it has the injection pump on it, but ive been told if i take the fuse out for the eltric pump and fit a facet pump it should work simialr to what that had in the old minis etc
Post by Darrell » Sun Dec 23, 2012 9:03 pm
Injection pump pressure is way to high at 38psi according to the manual. I don't see how the old carb put up with that though :er: . A facet pump would work fine normally but I don't know if it can draw fuel past the existing pump or if it can push it through the injection filter. Hopefully someone has done this who can give you more advice :thumbup:
