Hi all, after about 30 man hours i have allmost finished my 2 inch body lift lol.
atm it has
31 inch tyres
2 inch lift shackles front and rear
2 inch body lift
everything else is standard
DO i need to mod or change anything else to make this drive well on/off road with the extra 2 inch body lift?
I.e steering colum length, steering bar etc?
Thx, Rich
2 inch lift mods?
Re: 2 inch lift mods?
I would say wheel spacers. Unless your wheels have a real good offset. Otherwise it will foul chassis and possibly bulk head even though you've done the body lift on full lock.
- donkeychomp
What Jordi said but if you have a 413 transfer case, get a 410 one. I knoweth about 31" tyres with a standard case...you lose so much power...
- turbo-tom
ive got 31inch tyres on standard diffs, 1.6vit engine , 4 speed box and 410 transfere box and the gearing is good! its not brilliant but its good enough for me
Tom
Ford Fiesta ST
Ford Fiesta ST
the wheels are 15 inch vitara deep dish (10 inches wide) as far as i know they dont hit on the body but ive rolled the inner arches back alittle
Its a 410 with a 4 speed box, before i put the 31s on i had 27s and we could hit 74 mph
As long as it can sit about 55-60mph im happy, if not then i will get around to putting a 1.6 vitara or 3.5 rover engine in.
so as far as u guys know i shouldnt have any other probs with the extra lift?
Personally I would see if you can fit standard length shackles now that you have the body lift. it will improve the steering response and handling. The longest shackles I would run on an SJ with standard springs would be around 90-100mm between bolt centres.
