Starter moter wiring
lazy rambler
Post by lazy rambler » Wed Sep 26, 2012 3:57 pm
In the process of hooking up the wires now my 1.6 is in & the tags I put on the wires have worn off.
Anyone know what wires go where on the starter (pics would be best)?
Now a build in progress
Re: Starter moter wiring
Post by twiss » Wed Sep 26, 2012 4:30 pm
The battery +ve cable goes to the big terminal on the solenoid, the one furthest from the motor.
The battery -ve cable goes to one of the bolts that holds the starter onto the gearbox
There will be another connecting wire between the other big terminal on the solenoid that goes into the motor body.
Then there is just 1 small wire that goes onto the tiny terminal on the solenoid.
Post by ScottieJ » Wed Sep 26, 2012 4:35 pm
+feed from battery to + terminal as usual
Black/Yellow tracer from loom to the spade terminal
earth as in twiss's pic ;)
lazy rambler
Post by lazy rambler » Wed Sep 26, 2012 10:02 pm
Wired up and working now. Thanks.
