clifford alarm help please
jgp1986
Post by jgp1986 » Mon Feb 27, 2012 10:17 am
My samurai has a clifford alarm on but has no fob
now the thing is im after security but should i
*get a fob and get it programed
*rip it all out and replace
*rip it out and use other security eg pedal box.
i dont know if its worth having the alarm on a off/on road vehicle, could it potentially cause more problems than its worth or are they pretty good alarm
any input is appreciated thanks you
Re: clifford alarm help please
Post by Tramp » Mon Feb 27, 2012 4:13 pm
I don't know much about clifford alarms but mine came fitted with a gemini alarm system, It used to set itself off all the time and stranded me in a car park once, SO i ripped it out, It was pretty simple when it came out and the only immobilising it did was through a relay in line with ignition barrel, which I simple connected back together. Now I use a Disklock on my steering wheel instead
dominic
Post by dominic » Fri Apr 13, 2012 7:03 pm
I know its been some time ,
Clifford alarms r crap, they drain the battery so much, if you havent ripped it out yet,then do so.
Dom
Currently Drive
SJ 410 Q 1985 (GREEN)
VITARA GL+ 2017 (SILVER)
Post by turbo-tom » Fri Apr 13, 2012 7:05 pm
dont use alarms , i either wrap a chain lock like and oxford one around my pedals and through the steering wheel ;)
Post by twiss » Sat Apr 14, 2012 3:00 pm
Put this in your brake line with a bracket to lock it onto :)
Click Here for Ebay Listing
Post by Edweird » Sat Apr 14, 2012 3:16 pm
I was thinking about fitting a racing quick release steering wheel to my truck as security, but decided that the smaller wheel would make it a bugger to turn. One thing I do is leave the T-box in neutral in car parks, as some oiks these days probably wouldn't realise why there was no drive.....if they managed to get her to start in the first place.
Post by Anton » Sat Apr 14, 2012 4:48 pm
twiss wrote:Put this in your brake line with a bracket to lock it onto :)
I was planning on doing that to mine! One for the front axle, one for the rear. I've got the centre drum handbrake on my t-case, so it seemed logical, if I'm adding an "extra layer of protection" to add linelocks to the calipers. Hiding the controls of them seems like a great way to prevent the car going walkies. Individual linelocks could make great fiddle brakes, though...
