Welding?
Re: Welding?
Or sell it on ebay.
Edit.. Just had a look on ebay for reference and the big red water fire extinguishers are 9 litre.
Re: Welding?
Sounds about right. Think a 10L refill is about 45 quid for argon mix.
Re: Welding?
So approx 9 litres for £30 inc vat is cheap..dan_2k_uk wrote:Sounds about right. Think a 10L refill is about 45 quid for argon mix.
I got the sellers details from the http://www.mig-welding.co.uk" onclick="window.open(this.href);return false; forum..
They are http://www.jawel.co.uk" onclick="window.open(this.href);return false;
They have branches all over the midlands.
Bromsgrove 01527 835621
Burton upon Trent 01283 743700
Coventry 02476 637603
Dudley 01384 456069
Erdington 0121 377 6080
Smethwick 0121 558 6191
Stirchley 0121 471 3355
Tamworth 01827 261553
Wolverhampton 01902 736411
Oh and I've ordered a mig welder from machine mart...Pick it up on saturday
![double thumbs :doublethumbs:](./images/smilies/thumbup.gif)
Re: Welding?
So approx 9 litres for £30 inc vat is cheap..NotNewtomud wrote:dan_2k_uk wrote:Sounds about right. Think a 10L refill is about 45 quid for argon mix.
Still researching but it appears that it depends on the level of fill or bar/pressure and these are only filled to 50 bar.. Other bottles can be filled to 230 bar.
Re: Welding?
The one i was talking about is filled to 200bar from south west gas.
Dan
Dan
Re: Welding?
So if I've got this rightdan_2k_uk wrote:The one i was talking about is filled to 200bar from south west gas.
Dan
Your supplier sells you 10 litre @ 200 bar (£45) which is 2000 litres and at 10 litres per minute flow rate it would last you 200 minutes and cost 2.25 pence per litre?
Jawel will supply me with a 9 litre bottle @ 50 bar (£30) which is 450 litres and at the same flow rate would last for 45 minutes and cost 6.7 pence per litre?
If I've worked this out right? Yours is the much better deal. newtomud also newtowelding
![weld :weld:](./images/smilies/1welder.gif)
Re: Welding?
Im no expert but that seems correct.
I think you should look at a few other suppliers in your area and see what they have to offer
Dan
Dan
Re: Welding?
TBH I rarely run my gas on 10l/m you don't really need to unless its a bit draughty.
Re: Welding?
dan_2k_uk wrote:Im no expert but that seems correct.
Dan
Your right Dan so I looked up south west and they have a supplier fairly near me in Kidderminster..I'll give them a ringScottieJ wrote:TBH I rarely run my gas on 10l/m you don't really need to unless its a bit draughty.
Scottiej I was using the 10l/m for a reference to give me and idea of the different welding times on each bottle..But you're right it might be a bit draughty as I've no garage
![thumbdown :thumbdown:](./images/smilies/thumbsdown.gif)
