Ignition system - IT IS ALIVE
Re: Ignition system, just checking
I probably cut that wire out in that case
To be honest the only thing near it is reverse light connector.
I'll get it running and take pics of the extra weirdness!
Re: Ignition system - IT IS ALIVE
Well thanks for the diagrams chaps!!! Spent a while this morning wondering why it wasn't sparking, then realised I'd blown the ignition fuse
Gotta remember to turn the ignition off before connecting the battery!
Got it fired up for a couple of seconds! Can't do any more until Russ brings me some jubilee clips... cable ties are just not good enough for securing fuel hoses!!!
Then I've gotta mount the facet fuel pump... some kind of bracket required!
Have anyone got a pic of a facet fuel pump fitted on their SJ? I know it's a 12" lift pump so it's gotta be within 12" of the bottom of the tank.
Glad to hear you got it sorted
Why don't you mount the fuel pump along the chassis rail where turbo original fuel filter was.
Could do, but then I'd have to run the wiring to it as well... and wait for russ to get more more fuel hose.
I'd rather keep it in the engine bay. I was thinking I might mount it to where the airbox used to be
