Coil conversion
Coil conversion
Post by Jordi » Tue Jul 12, 2011 12:26 am
Coil suspension anyone?
Can't find a great deal of info about it anywhere and wondered if you fellows had any ideas? Its not that i want bigger tyres just a better ride and better articulation.
Im looking at a few options. Dont really wana go spoa as it will just make my Zuk higher unneccesserily (u try spelling it).
All i've done so far is go to 31s and a virtual lift. Trying to keep it low n wide.
Also needs to be road legal.
ferris
Re: Coil conversion
Post by ferris » Tue Jul 12, 2011 11:15 pm
I always thought i would get my SJ coiled at some point, untill i found out how much was involved :shock: .
Check out this build thread.... http://forum.difflock.com/viewtopic.php?t=63086" onclick="window.open(this.href);return false;
I think YJ spring conversion is the next best thing. If you can get hold of a set of springs.
rockwatt
Recommended Trader
Recommended Trader
Re: Coil conversion
Post by rockwatt » Wed Jul 13, 2011 8:05 am
ferris wrote:I always thought i would get my SJ coiled at some point, untill i found out how much was involved :shock: .
Yes it is alot of work but well worth it when it's done. The difference between a leaffer and a "good" coil job is night and day.
But a bad coil job can be less capable than a good leaffer.
One bit of advise don't get to wraped up in how the yanks do it as most of there setups realy don't suit our terain. Horses for courses as they say.
I do agree with the low and wide, mine only runs a 2 inch lift on 33's and you have to push it dam hard to get it over.
Rocklobster gears , refurb cases , dual cases , su manifolds , jimny rocklobster conversions inc speedo drive, t/case heavy duty mounting arms and rock buckets, bespoke fabrications and machining,
Contact me for details.
Re: Coil conversion
Post by twiss » Wed Jul 13, 2011 9:19 am
Rich you should specialise in SJ coil conversions ;)
Re: Coil conversion
Post by ROBBIE » Thu Jul 14, 2011 1:24 pm
twiss wrote:Rich you should specialise in SJ coil conversions ;)
at very cheap prices ;)
Re: Coil conversion
Post by Edweird » Thu Jul 14, 2011 9:03 pm
Thought those were torsion bars for a minute. Can't remember their proper name now either.
rockwatt
Recommended Trader
Recommended Trader
Re: Coil conversion
Post by rockwatt » Sat Jul 16, 2011 7:01 pm
Umm that's the reason I don't ! Far to much work and to many hours go in for what poeple want to pay. Realistically there is at least 2k in parts and labour for a coil setup like paul's ! And how many Sj owners want to spend that.
If you think that's steep then look at rhino rays kit for £1400 and it's essentially modified scrap parts :shock:
Re: Coil conversion
Post by ROBBIE » Sun Jul 17, 2011 8:46 am
rich if i had 2 grand mate i would be on the phone to you right now 8-)
Re: Coil conversion
Post by twiss » Sun Jul 17, 2011 4:01 pm
ditto :)
