Lwb Santana 1.3 Hif44
Re: Lwb Santana 1.3 Hif44
Post by Rankine » Fri Jun 06, 2025 8:50 pm
Definitely man happy to travel once I fix the brakes 😂
Flumps
Post by Flumps » Fri Jun 06, 2025 9:06 pm
Well done!
Brakes?
I would describe mine as 'progressive' a slow reduction of speed followed by a trailing fade!
Nice to see all green on the Gov website 👍
Post by Rankine » Fri Jun 06, 2025 10:38 pm
Sounds pretty accurate 😂 they do fine about fields not sure about how effective would be on the road
Post by Rankine » Sat Jun 14, 2025 8:06 am
So I've started my rear disc swap.
I bought a ebay disc conversion kit that just came with the caliper mount and backing plate for disc. I had the rear calipers of my old primera and thought I'd try make them fit instead so I would have a working handbrake.
To get them close I had to weld up the old holes in mount and bring then closer in to axle for a better position on the disc. Also had to machine (grinder job) the carriers down to fit between the disc and the mount.
Only done one side so far. Will still need to modify the handbrake cable mount to suit. Also still waiting on my wheel studs, and I'm going to need to order some new banjo and slider bolts.
d_r_1989
Post by d_r_1989 » Sat Jun 14, 2025 12:57 pm
Be a brilliant handbrake that once it's together. Good effort with the fabrication :weld:
Post by Rankine » Sat Jun 14, 2025 5:59 pm
Cheers man, hopefully these and bias valve sorts breaks. If not new master cylinder ideas
Post by ScottieJ » Mon Jun 16, 2025 12:44 pm
Nice work, it’s deffo handy being able to use something you had lying around!
The GV master cylinder and servos aren’t that hard to fit, can get them in 15/16” and 1” so a good size upgrade. Just make sure to get one out of a GV with ABS so the MC only has 2 outlets to make it a bit easier.
Post by Rankine » Mon Jun 16, 2025 9:28 pm
I think I better get one. They could hopefully get them done in one go. Gonna have a look the now for one. Don't suppose you've one for sale?
Post by Rankine » Sat Jun 28, 2025 8:26 am
Well I had to make some changes 😂 drilled holes to far in then damaged a carrier trying to make it fit. So had to reweld the holes and order some new carriers.
But both retaining plates/carrier mounts are now painted and fitted. And I'm going to take the new carriers to a machine shop to get 4mm taken off of them.
Post by Rankine » Tue Jul 01, 2025 8:47 pm
Dropped the carriers off yesterday got them back today, primed and painted them tonight after got the little one down. Hopefully get the all fitted up at lunch tomorrow.
Then it's the axle flexi to change and bias to fit
