got a grand vitara on a 08 plate,73 k 1.9ddis AWD 3 door
dpf is duff and kicks in on the limp mode,
had the forced regen done a while back but that's failed can and do the replacements on ebay work? and if so who does the best one,
thanks,
bob.
failing that anyone want to buy it,
dpf replaceent
Re: dpf replaceent
I'm not suggesting you do this, but people have been known to gut their DPF and refit it as a straight through pipe.
DPF "filters" are not filters at all. They're temporary soot storage systems that capture soot at lower temps, then emit it when you're moving faster/exhaust temps are higher.
Re: dpf replaceent
thank you
has anyone used a ebay replacement one and then had the remap,done?
bob
bob
