copper less mig welding wire
parrotveasey81
Post by parrotveasey81 » Wed Nov 03, 2010 6:53 pm
my works welding rep poped in today with a free 15kg roll of copper free mig welding wire for us to try out.
it cost £2 more per 15kg roll
has less fumes
50% less spatter
plus a few other benifits i cant remember
well it has the same amount of spatter but is easyer to get off,has less fumes but is alot smoother to weld with and gives a better weld with the same settings(just need to back off the tension on the wire feed rollers)
so im hook'd on it just need to try and get the company to get it in all the time.
with copper wire
parrotveasey81
Re: copper less mig welding wire
Post by parrotveasey81 » Wed Nov 03, 2010 6:55 pm
with copper less wire
Seth
Post by Seth » Fri Nov 05, 2010 11:42 am
Those welds are artwork, it's saying something when that level of skill can be improved on just by a component in the wire.
I was awestruck at your Vit chassis build.
Post by ScottieJ » Fri Nov 05, 2010 12:10 pm
as if your welding wasn't pretty enough as it is! I might have to try some of that wire, looks :smoke:
Post by dan_2k_uk » Fri Nov 05, 2010 1:27 pm
hopefully you can do something like that to my jeeps body soon.
hows sorting the vit going. i have spoken to the guys at work who are working in trowbridge who think they could chuck it on their low loader when they use it to pick up their diggers from site within a week or so.
Post by ScottieJ » Fri Nov 05, 2010 1:39 pm
The vits been stripped of all the bits we wanted and it's ready for the scrappy! :mrgreen:
Post by dan_2k_uk » Fri Nov 05, 2010 3:32 pm
good shiz. i look forward to a few weekends of garage based antics!
SJ-Mini
Post by SJ-Mini » Fri Nov 05, 2010 7:27 pm
Wish I could weld!
Post by Edweird » Fri Nov 05, 2010 9:25 pm
SJ-Mini wrote:Wish I could weld!
I've welded a bit, but only on thick-ish stuff, like 20x20 box and angle section . I'm not sure how I'd do with bodywork, probably end up with more holes than before I stated :lol:
dunk
Recommended Trader
Recommended Trader
Post by dunk » Sun Nov 07, 2010 9:40 am
Who is your welding supplier ? I might have to give that a go :smoke:
